Cart before the horse? Or an error in memory?
Post Reply
drobnock
Registered Member
Post by drobnock »
Of course, none of us are old enough to have bought our Model T new. But reading the work of Murray Fahnestock, contributor to the Ford Owner, and the Ford section in Dykes, as well as "The Model T FordOwner" (sections republished by Dan Post).
Fahnestock lived in Pittsburgh, Pa. in 1914. Pittsburgh at that time had a Ford Branch Factory.
In Fahnestock's text he stated that his first encounter with the Model T was in 1914, after years of such cars as Peugeot, Pittsburgh Six, Mobile steamer, and a Reading-Standard, Harley-Davidson, and Thor. He stated that he bought a Model T new.
What is interesting about his purchase was this, Fahnestock stated he bought his car 1 August 1914. The Motor Number was 554,792, a roadster for $440.00
A review of the McCally book (Section on "Engine Serial Numbers") indicated that
engine number 554,792 was part of the production 11 August 1914. The engine was on the line with 554610 to 555186 that day, according to the McCally's work, 670 units were produced.
Russ t fender
Registered Member
Re: Cart before the horse? Or an error in memory?
Post by Russ t fender »
Looks more like a typographical error but which source is wrong?
46woodduck
Registered Member
Post by 46woodduck »
Did he take delivery on August 1, 1914 or just purchase the car on that date?
I could be a typo or he could have purchased the car and taken delivery at a later date if the dealer didn't have the model he wanted in stock.
Life is good on the lunatic fringe, Tom
drkbp
Registered Member
Post by drkbp »
46woodduck,
You make a very good point and one of several possibilities.
The motor assembly dates for 1913 and 1914 in Bruce's Book suggest motor number 554,792 was assembled on August 11th so it couldn't possibly be assembled into a car until after that date. If the completed motor was shipped to PA, got to be another week, so we are probably looking at no sooner than the last ten days of August to be in a car.
Also, the 1915 motor assembly dates are backed up by records only 4 months later. Add to that the daily unit production numbers are known for 1913 and 1914 and Bruce apparently assigned dates based on those numbers.
What we do know today is we can confirm some of the dates of motor assembly in 1913 and 1914 that appear in Bruce's Book. They appear to be correct and this is why:
The casting date on the block will precede the date of the transmission stub shaft and both will precede the date in Bruce's Book for engine assembly.
Example:
1) motor number 312,XXX,
2) casting date June 19, 1913, a Thursday
3) transmission date July 11, 1913, a Friday
4) motor assembly date (Bruce's Book) July 17, 1913, a Thursday
It is easy to see that if the dates were "off" 3-4 weeks "earlier" to meet Murray's recollection, the above example could not happen. The transmission date is hand stamped on the stub shaft so we have only six days before motor assembly. Close, but probably correct.
They dated the transmission stub shafts into 1915 I believe. It began with the 1908's and I have a picture of 12-3-14 but I don't know how long that went on.
I would speculate that Murray's memory was off a little or you are correct 46woodduck.
TRANS STUB SHAFT (480 x 360) (2).jpg (47.57 KiB) Viewed 361 times
Post Reply
