Repairing the Model T Ford Rear Spring
Post Reply
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
The article is here:
https://modeltfordfix.com/repairing-the ... ar-spring/
Please use the Reply button below to discuss this article.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
original smith
Registered Member
Re: Repairing the Model T Ford Rear Spring
Post by original smith »
One point I would like to add, is the late Fords used a special square headed bolt that is 1/4-20. and a hex nut for the end that is 1/2" across the flats. The style of the bolt is the same front and rear, just longer on the rear. The four corners on these bolts are very slightly rounded, and have a 3/8" head on them. These hold the spring clip in place. In later years, Ford replaced the leather pad with one made of top material, but still had the leather ends on them, held on with two split rivets. I prefer to use the all leather pads front and rear. Although not original for the late cars, the early center retaining bolts, especially for the rear, make installation much easier, and stay in the frame better. I hope I'm not confusing anyone here by not using Ford's terminology!
Post Reply
