The Model T Ford Hubcap
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
The article is here:
https://modeltfordfix.com/the-model-t-f ... cap-t2819/
Please use the Reply button below to comment.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
original smith
Registered Member
Re: The Model T Ford Hubcap
Post by original smith »
I have a number of original hubcaps from the late 1912-1917 period. I have a mint 1917 nickel plated hubcap with the black background. A portion of the black paint is coming off, and it is brass underneath. It still has the high F.
original smith
Registered Member
On one of the photos showing the high F hubcap, the one on the right is a '13, and the left is a '14-16 style. Notice not only is the F higher in '13, but is fatter to. I've been studying '13s for over 50 years, and this is my conclusion. I have no documented proof.
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
Larry,
Ford used the high F hubcaps into 1917, with nickel plating and of course a black background as was used on all hubcaps from about 1912 - 20. There were likely more than one supplier so there might be both types of caps being used in some years. As far as documentation goes if you have a photo from a certain year that shows what you describe and then you restore the car that way no one can say that you are wrong.
Ford factory photo September 1914 new runabout.jpg (28.25 KiB) Viewed 746 times
1912 wheel.jpg (114.71 KiB) Viewed 746 times
1910 Touring
1914 Touring
1915 Touring
User avatar
Jay In Northern Ca.
Supporting Member
Supporting Member
Post by Jay In Northern Ca. »
Here's a set of ALEMITE Accessory Aluminum Front Hubcaps that allow you to grease the wheel bearings without removing the hub cap.
alemite hub caps.jpg (88.08 KiB) Viewed 733 times
alemite hub caps 1.jpg (61.21 KiB) Viewed 733 times
alemite hub caps 2.jpg (99.84 KiB) Viewed 733 times
original smith
Registered Member
I don't believe any reproduction hubcap has a manufactures symbol at the bottom. I believe the one above you are referring to is an original.
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
Yes, the text in the article is referring to the "B" on this original 1917 - 20 hubcap.
original smith wrote:
14 Sep 2018, 15:44
1910 Touring
1914 Touring
1915 Touring
original smith
Registered Member
I have an original 1917 nickel plated hubcap in my collection. It is mint, and a small amount of black paint is flaking out of the center showing brass beneath it. It still retains the high F in the script too, like a '15.
original smith
Registered Member
Here is a picture of a mint used 1917 hubcap. Note, there is no plating under the black paint, indicating to me that the black was applied before the nickel.
1917 HubcapSCN0509_653.JPG (83.11 KiB) Viewed 646 times
original smith
Registered Member
I'm posting some new photos of early hubcaps from my collection. Like Royce, I've been studying this subject for many years. I've arrived at my conclusions from this after looking at many documented original untouched cars. You will not find this information at the archives either.
13 & 14 Hubcap.JPG (119.64 KiB) Viewed 629 times
Post Reply
