The 1911 Model T Ford Part 1 - the New Runabouts
Post Reply
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
Article is here:
https://modeltfordfix.com/the-1911-mode ... runabouts/
Please hit the Reply button below to discuss this article.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
David Mazza
Registered Member
Re: The 1911 Model T Ford Part 1 - the New Runabouts
Post by David Mazza »
The open runabout is simply my favorite model t! I'm sure the torpedo and runabout have inspired thousands of speedsters! I know it has mine :D
User avatar
Roger Byrne
Supporting Member
Supporting Member
Post by Roger Byrne »
Thanks Royce for the great article on the 1911 Torpedo and Open Runabouts! I own a 1911 Open Runabout and even though it's a "put to gether" of correct period mechanical parts and Rootleib body/fenders, I still feel lucky to have it. Since the photos below were taken, I have found a correct "potato" horn for it and have a set of gray tires that need to be installed. I have also have a "correct"??? tool box for it like the ones used on the 1912 version, but at this point, knowing that it never came from the factory with a trunk, I'm not going to install it and just leave it on the shelf for the cars next caretaker.
Top Down .75 Right.jpg (164.58 KiB) Viewed 512 times
Top Up .75 Right.jpg (209.28 KiB) Viewed 512 times
Right Side.jpg (176.69 KiB) Viewed 512 times
Left Side.jpg (137.32 KiB) Viewed 512 times
As a side note, the car is a very dark blue and unless it is in bright sunlight, it appears almost black. That is part of the reason the photos above have a big variation in the color of the car.
Preserving Mechanical History for Future Generations since 1965
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
Roger thank you for the kind words. Your car is one of the few restored cars that I can look at and not find much of anything that I would change to make it better. Thank you for sharing the photos!
1910 Touring
1914 Touring
1915 Touring
Post Reply
