The 1909 - 1910 Ford Part 2
Post Reply
User avatar
Auto Inn
Site Admin
Site Admin
Contact:
Post by Auto Inn »
The series continues - new one is here:
https://modeltfordfix.com/the-1909-1910-ford-part-2/
Hit the Reply button below to comment.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
scott rosenthal
Registered Member
Re: The 1909 - 1910 Ford Part 2
Post by scott rosenthal »
Great lamp article Royce. Interesting that very similar Jno. Brown carbide generators appeared in multiple versions that seem to offer little if any performance improvement, from one style to the other. This same lower tank was also offered with a (4) hole base mounting, both cast and spun brass base construction, and also used a ratchet tightening clamp arm instead of the wing-nuts for the top tank. Anyone out there know if there is a chronology of these versions, or perhaps whether all versions may have been available during the same timeframe?
Regards,
Scott
Post Reply
